Please make call control
Makecallcontrol
I’m tired of spam callers.
@Makecallcontrol
We get them all the time. One option is to install the Truecaller app and it will screen out spam callers in their list.
Meow
NOT going to happen at PM... Just do not pick up calls from unknown callers...
hairbag1
The 2nd best option is this...just don't answer any calls unless you recognise the calling number. If it's a legit call, they can leave a voice message and you can call them back if you wish. If the bad guys know you answer all calls..well...you're finding out what happens. Using the suggestion I propose...you're spam calls with diminish...I get 1 or 2 spam calls per month now. It'll work if you adopt this concept.
hi @Makecallcontrol
not to lie, I don't think it will come here
Public Mobile is a tier 3 carrier, and Call control is a feature only offered with Tier 2 and Tier 1 carriers.  If you need it, you will have to check out Koodo and Telus
