Please enter a valid SIM number
emal777
Bought a pm SIM card, when trying to first activate it, on the very first activation page, I get this message: "Please enter a valid SIM number". Not sure why does not accept it. Any suggestion?
Thanks!
Emmanuel
10 REPLIES 10
dust2dust
@ernsyans- I might not be entirely convinced that that's a Public sim. Again, where did you get it? Who mentioned that the company is a scam???
No it also doesn't work for me. Nor in Koodo prepaid. Did you try it in a phone? If a phone number shows up in sim details then that's a problem.
ernsyans
ernsyans
I  bought a brand new sim not in used when I call them they said that there is no issue with that sim. they even mentioned that the company is a scam. don't truth them
@ernsyans- Have you tried all the new sims? Where did you buy them? Is it possible you bought a pre-packaged, already activated deal? Have you actually tried the sims in a phone?
This place is not a scam. You're just having some unfortunate experience.
ernsyans
yeah you right I tried all browsers on my pc and on my phone still showing the same issue.
This company is simple a scam company. they are the one suggested me to buy a Telus sim card. now I lost my money because they refused to activate it
@ernsyans- Did you try on a non-mobile device? If on a mobile, try desktop mode. Also try private mode. I don't think any provider will refund sim purchases.
ernsyans
same issue and my problem can't bee fix,  Please enter a valid SIM number. I tried all browsers.
this company look fake no one to help.
And I paid $30 for my sims they don't want to give me my money back
@emal777 you entered the full 19 digits correctly?
Try  on another browser and see ifnit works.
If not, it could be a mix up and your sim is actually one that activated before.  Did you got the sim card from a store?
You can open ticket with PM support and they can check if the sim card was used and advise
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
Timer
@emal777
if your SIM card is new and us you still not activate contact to support team by CS_Agent
Timer
@emal777
use browser from computer,and clear cache and cookies and use one page inPrivate mode,
