06-01-2020 02:52 PM - edited 01-05-2022 10:59 AM
This is on behalf of my sister new flip phone. She can call us okey BUT long distance charge is applied when we answer her call. Please fix! Her phone#
what can’t we call you?
Please give us your # to call.
Thanks.
Phones
06-01-2020 09:42 PM
@nildasan7 has to clarity what the problem actually is so we can help. We seem to be just guessing.
1. Your sister has a "new flip phone". So can we assume she has a mobile phone account?
2. Is her phone account with Public Mobile?
3. Who is being charged long distance? She or you?
4. If when she phones you, a voice message announces that "long distance charges may apply", then she does not have to worry. Neither one of you will see any charges. To avoid that message, she may add the number "1" in front of your number when she dials your number or any other phone number in Canada.
5. Don't try to change her phone number unless when you phone her from a landline and you get charged for long distance. In that case she can change her phone number with Public Mobile so the area code is the same as yours.
6. Public Mobile's support is online only. So there is no voice phone call support. There are many fellow customers who are willing to help. But it helps them to help you when your problem is clearly stated.
06-01-2020 08:39 PM
@nildasan7 wrote:This is on behalf of my sister new flip phone. She can call us okey BUT long distance charge is applied when we answer her call. Please fix! Her phone#
Thanks.
All tech support, and account enquiries, at Public Mobile is online. As already suggested your sister must change her number to one that is not long distance for you. We assume your sister has a PM account. She can do this by logging into her self serve account and selecting Change My Number.
06-01-2020 04:17 PM
There is no way that the person BEING CALLED is getting charged for a long distance call when they answer. Need more info ....
06-01-2020 03:09 PM
@nildasan7 tell her to change her phone number on her self serve account so you guys don't get charged. I'm assuming she's on public and you guys are with a different provider
06-01-2020 03:02 PM
@nildasan7 I gather your sister has a landline. Its the second set of numbers that determine whether your cell number is local or not. Ie xxx yyy xxxx. Please check the CNAC website to check if your number is local or not http://www.cnac.ca/co_codes/co_code_status.htm . The only way to stop her being charged long distance when calling youis to change your number to the desired local area code. You can do it once each 30 day cycle through your self service account. Welcome to the community. Stay safe.
06-01-2020 02:59 PM - edited 06-01-2020 03:08 PM
Thanks.
@nildasan7 With PM being prepaid there's no way to be charged for any overages as you only get to use what services you've already paid for, so as suggested you can ignore any messages to that effect.
Edit: After re-reading your question and @gblackma's response, can you clarify if your sister is with PM too?
06-01-2020 02:54 PM
Thanks.
Add a 1 in front of all called numbers. It's just an old recording from days gone by. You can ignore it as there are no extra charges here.
This is an online support service. There's no one to call.
