Making calls in US
Queen1
Am I able to use my phone to make calls within the US and from the US to Canada for free with my current subscription?
hairbag1
@Queen1
if you're in US, you wanna make sure your cell is VoLTE recognized with Public Mobile...otherwise text and data will work fine but all calls will fail. Enable Roaming so data will work...don't worry about overages or extra billing...there are none. Here's some reading with a device checker at the end of the article.
https://www.publicmobile.ca/en/get-help/articles/volte
ed
Sansan
If your current subscription is can-us or can- us- mx then yes you can. You also need a volte enabled phone on Public Mobile's whitelist.
Dunkman
@Queen1
If you are on the Canada-US- (Mexico) plan, then you can make phone calls for free from within the USA.
