06-22-2021 11:56 AM - edited 01-06-2022 02:36 AM
Is there a way I can add family members to my current plan ?
06-22-2021 07:04 PM
@radiantmoyo wrote:Is there a way I can add family members to my current plan ?
You can register the same credit card to more than one Public Mobile account, but that is about all each account can have the same of.
06-22-2021 02:18 PM
You can set your family's accounts up using an email alias for each account so all communication goes to the same email account. For example if your email is [email protected] you could set up your family's accounts up with [email protected], [email protected] etc...
There's also the advantage of capitalizing on rewards with separate accounts. If there are 4 members you will recieve :
Then there are the free gifts.This past xmas the "more the merrier" campaign gave away a 2gb data add on(value $30) + 500 international long distance minutes add on(value $25)×4=$220 in free gifts.
Just be sure when you do activate (on a flash sale promo!!) that you don't have more than two accounts renewing on the same day with the same credit card. You can space the activations out before and after midnite eastern will have the accounts created and renewing on separate days.
06-22-2021 12:25 PM - edited 06-22-2021 07:13 PM
public mobile not have to add family members,
you need a new Email, and new phone number or your old number Transfer,
and set up everything the same information credit card and password and 4 digit pin,
all the same with your family is will working just a new Email you need it for each a new account ,
Set Up AutoPay means that you earn $2 every 30 days!
add Refer A Friend code your friend will receive a one-time credit of $10.
for each account your Refer, and you will earn $1 every 30 days for each account,
Good Luck and your family welcome to public mobile
with a Beautiful Service
you will be very happy
06-22-2021 12:02 PM
Unfortunately, PM does not offer family plans. Each account can only have one sim and phone number.
06-22-2021 12:01 PM
@radiantmoyo PM does not have share data or share minute plans.
Also, if you decide to help your family member to activate another account, you will need to use a different email address to create the account. With PM My account, one email address tie to one account.
Of course, don't forget to use your own referral code when you activate for your family
06-22-2021 11:58 AM
sorry, PM does not have family plan 😞
