08-28-2022 05:40 PM
Hi, I put in for the new cell plan with 4gb at 4g speeds for $41 and it was supposed to take effect on the next billing cycle which was Aug 18 but when I check my profile it still shows the old plan
08-28-2022 06:08 PM
it is just a glitch in the system there is a new design it is affecting some customer
use browser from computer,and clear cache and cookies and use one page inPrivate mode,
or safari on private mode, To Login Page check it, payment history it's charged for new plan cost.
or maybe the change plan not going through,
reschedule to change plan on next cycle or contact PM support team by CS_Agent to Manually changed plan.
08-28-2022 05:46 PM
you can also send a direct messagge to a customer service agent and ask for help
Message Agent here:
08-28-2022 05:42 PM
Click on the little spinner refresh icons lower down. Maybe the proper plan will display. Or use a different browser or device or use incognito.
08-28-2022 05:42 PM - edited 08-28-2022 05:43 PM
With this new site, you likely still reading off the cached version, so the Plan detials you got was not up to date
Try to login My Account using Incognito mode (or InPrivate for Edge, Private for Safari) or try again with a completely different browser like Edge/Firefox/Chrome. You should then see the latest Plan details from the server that way
Add: Also, the new speed might not come after around 48 hours
