Plan switch
08-08-2022 10:12 AM
I currently have the $40 plan for 5 gigs at 3G. If I switch to $45 plan at 4G, will I lose my $12 referral discount that I have? Or will I have to pay the full $45?
Thanks.
Plans
08-08-2022 10:15 AM - edited 08-08-2022 10:16 AM
@Nbhiker you won't lose your $12 referrals discount just because you change plan
HOWEVER, if you make a request to "Change plan now" , which mean PM will start a new plan immediately, they won't apply the rewards for this particular time. ie, you are paying $45 this time. You will get your rewards again on the next renewal and the renewals after
So, to minimize the lost, you can schedule a plan change using "Change plan in the next renewal date" and then PM will apply the rewards when they change plan at the regular renewal date, ie, you only paying $45-$12 = $33
08-08-2022 10:15 AM
No you will keep that still as long as you don't opt into the new rewards.
08-08-2022 10:14 AM
@Nbhiker - no you will not lose any friend referrals when you change plans.
You will need to pay the full amount IF you choose to "Change Now".
Best to choose to "Change on next renewal" so you do lose out on any funds in this current cycle already paid for..as there is no prorating that.
08-08-2022 10:14 AM - edited 08-08-2022 10:15 AM
@Nbhiker Hi no you will not lose your referral that you have now but if you change your plan early you will lose the remainder of what you paid for your old plan so it is best to change at your next renewal date
