Plan renewal
Sing0763
Is it possible to renew your plan before the renewal date? I would like to know if we can pay for the plan earlier to get the services of that  new plan instead of waiting for the due date.
chukdefatey
@PAULRANG18 wrote:
If you renew early before plan renewal date, you will not get a refund for any unused minutes or data. PM  is a prepaid carrier.
What does Public Mobile being a Prepaid Carrier has anything to do with it?
darlicious
@Sing0763  The correct answer to your question has been posted by @ChuckYeah . You can change your current plan now to a different one thru self serve but you cannot renew your current plan now without asking the moderators to do it for you.
PAULRANG18
ChuckYeah
@Sing0763 , if you want to change to a higher plan, you can do so through self serve. If you want to renew the same plan, you must go through @CS_Agent .
Creating a support ticket:
Explain your issue to SIMON, seen below:
Use as few words as possible to allow the BOT to understand (renew plan early). Answer his questions until you get here:
Click on "Submit a ticket" and the Moderator team will respond to your concern, usually within 48 hours.
Alternatively, you may send a private message to moderator through the following link :
Contact @Moderator_Team
About @Moderator_Team
Moderator Hours
Monday-Friday: 8AM- 12AM EST
Saturday & Sunday: 8AM-10PM EST
popping
Yes, you can change to your new plan early using self-serve online before your renewal date.
Please note that there is no refund of the unused days of your current plan.
