Visual voicemail?
Prima_Facie
Does Public Mobile offer visual voicemail? Or can it be included in a plan as an add-on?
By visual voicemail I mean where you can see your voicemail messages in a list and switch between them, select them, view info about them, etc.
I believe iPhones generally have this feature as an optional add-on from your service provider plan.
Thanks in advance for your responses!
luke11992
@PAULRANG18 wrote:
Visual voicemail is not offered with PM. I don't believe any other carrier offers it, either.
Other carriers do offer it, it's just part of PMs "less for less"
Kim1971kim
I don’t think they offer that but that would be cool!
PAULRANG18
ChuckYeah
No, i'm afraid not. And it is adviseable to disable Visual Voicemail "before" porting into PM as well. It has been known to cause problems with traditional voicemail indication for some.
popping
PM does not offer vistual voicemail and there is no visual voicemail add-on.
