10-04-2022 05:38 PM - edited 10-06-2022 09:03 PM
Just curious why the 40gb plan appears and disappears in the plan options ? The 40gb plan is best for me because I have no home internet because my only option is Xplornet and they are not that good. Make the 40gb plan available always !!! Rant over have a good day
Thank you for all the responses got it all figured out !!! 🙂
10-04-2022 07:27 PM
not-trust-anyon ...Can you please use Google translate for your posts?
Thanks
10-04-2022 06:44 PM - edited 10-04-2022 06:51 PM
The OP also hasn't come back to clarify their statement, what time frame they are talking about, if they are a client already or just looking at the advertised plans etc.
Edit: it looks like @clee72 is an existing customer... so they could/should schedule that plan change, or change immediatley if they are out of data on their current plan. but it would still be nice to have more information to pinpoint the problem instead of just guessing.
But yeah, if I wanted / needed that much data on my cell phone and would be willing to pay that much for the privilege, I'd jump at it pretty much immediately. Who knows what changes are happening next.
The screenshot in the post above implies that it is available for a new sign-up. I will not mess around with my personal account until I actually know what is happening at the next renewal date so I can't confirm that the plan in question can be selected for a plan change.
10-04-2022 06:34 PM
Maybe ,it was removed from the website by mistake? I'm just as surprised that this plan is shown in one location but not the other. I was only going by how the publicmobile.ca plan page was no longer showing it.
10-04-2022 06:28 PM
.. with PM history, likely it's another glitch. Someone forgot to remove the plan when they update the new one. LoL
10-04-2022 06:28 PM
@computergeek541- Strange? This place? 🙂 I haven't looked again since I wrote that. No way I'm spending $95 anyway. But it would be interesting if it can be picked.
10-04-2022 06:25 PM
Does it keep disappearing and reppearing? It does shows up for me too. It's strange that it's no longer being advertised.
10-04-2022 06:08 PM
Yes if I go in to change plans I see the 4G $95/40gb plan. Pick it while you can. And hopefully they won't yank it out from under you like they did to wetcoaster.
10-04-2022 06:00 PM
In addition to RossN's reply: Once you are on it it'll renew as the same plan after 30days, so... not sure what exactly you mean?
10-04-2022 05:56 PM
@computergeek541 hi it still shows it in plans and add ons?
10-04-2022 05:55 PM - edited 10-04-2022 10:44 PM
10-04-2022 05:45 PM
@clee72 hi if you go into your self serve account go to change plans ,to the far right you can scroll down in the 4g plans and you will see the 40 gig plan 😁
