Plan explanation
denisep1
Can any explain why I am receiving texted messages giving me updates on % used up when I emptying for unlimited use? Please
7 REPLIES 7
denisep1
Thank you so very much
@denisep1 you can login to your self serve account and it will show you the details of your plan and how much data you've consumed
denisep1
Thank you. I dont do very much and dont know why I would've used up so much.
Luddite
@denisep1 Do you have the $10 or $15 plan?
gblackma
@denisep1 there are no unlimited data planes here. The highest amount you can have is 8.5 gigs with autopay on the $50 plan. You receive 611 warnings when 75 and 95% of your data is used up. Welcome to the community.  Stay safe.
denisep1
Thank you, Dou you know how to check what coverage I have and how to
will13am
@denisep1 , all Public Mobile plans with data are limited usage.  You do get notifications when reaching certain usage levels.
