Plan didn't come out right
Bee17
Hi. My current plan is the $35 plan. On the 27th my plan renewed and the $35 came out. My phone just stopped working for phone calls so I checked my account. When my plan was to renew they took $15 and left the other $20 in my account. So it gave me 100 minutes of calling and $5 worth of data. So now I can't make phoen calls and I have hardly no data. I did not want that plan I wanted my $35 plan. I would like this to be fixed. Thanks
JL9
It sounds like either an inadvertent plan change on your end or a glitch in PM's system. Either way a CSA should be able to manually get you on to the $35 plan and have the funds cover it from your available balance.
HI @Bee17
did you ever attempt and make a plan change to the $15 plan?
And it was $35 plan? or you were on $15 plan and tried to make a plan change to the $35 plan?
It is not too many days into your cycle, maybe PM CS agent can still fix it by changing it to the$35 plan for you.  Please open ticket with them:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
start by typing : Contact CS Agent
then Click "Contact Us"
then Click "Other"
finally Click "Click here to submit a ticket"
RossN
@Bee17
contact a cs agent explain your issue
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
