01-26-2023 07:07 PM
I made a plan change before the payment date and I was charged the new amount ($40 is the new plan) , but now my plan has reverted to the old plan ($25 plan). I was looking forward to the 15GB data.
Payment
01-26-2023 08:43 PM
Thanks. It worked with incognito!
01-26-2023 07:24 PM
Hi @Esly
Logout and close all browser and clear cache/ cookies/ open inPrivate mode,from computer. Login again.
01-26-2023 07:16 PM
HI @Esly likely you are ready the cached page. PM site has cache problem
best to check again using Private/Incognito/Secret browser mode. You should see the new plan that way
01-26-2023 07:14 PM
@Esly if once you refresh your screen and you see the new plan change on your account, then that is good.
Were you also questioning why you were charged the full plan changed amount? If so, this is normal, there is no prorated of the plan you were currently on when changing plans early. That is why many recommend to change plans on next renewal date.
If you were just telling us you were charged for the new plan, then good for you, because that is good information to know and this is due to likey a cache/refresh issue on My Account, which tends to happen often.
01-26-2023 07:09 PM
01-26-2023 07:08 PM
Try again incognito mode/private mode or a different device or lap top or simply try refreshing the page when logged in
