Plan change results in no voice calling
akinaduh
Added nationwide voice calling to my plan.  Now I cannot make voice calls.  Message says that I don't have a long distance add on to support this call even though it is a local call AND I have a long distance package.
Messaged moderator but no reply.  How long will it take to have this fixed?
akinaduh
Thanks for the reply.
closng
As the day just started, the Moderators should be able to help you soon, as they deal with issues in the order they receive them. Sit tight!
Taekgun
@akinaduh
You've definitely hit a glitch with the self-serve portal - appears to happen for some people with a plan change.
You've done the right thing by private messaging the mods.  You just need to wait for their response now.  Make sure when you messaged @CS_Agent, you included your name and account number along with your explanation of what happened.  Shouldn't be too long.
