03-02-2024 11:46 AM
03-02-2024 11:49 AM
You will keep rewards.
03-02-2024 11:48 AM
@Lorne_Grant change plan won't affect the rewards system. I can confirm that as I changed plans many times
So, you will get the same rewards discount as before after plan change
03-02-2024 11:48 AM
NO. Rewards are tied up with your account not plan so you can change plan every 30 days if you like without losing any rewards.
