04-07-2020 03:37 PM - edited 01-05-2022 10:16 AM
I have an unlocked sonim xp3800 and I can't receive picture messages. Everything else works great. I have checked the APN settings as well as making sure data was turned on and nothing works. Have done factory reset and network reset as well.
04-10-2020 03:31 PM - edited 04-10-2020 03:33 PM
most phones nowadays should be able to send recieved picture messages. just try resetting network settings restart the phone and make sure your data is on. turn off wifi to make sure there's no interference
04-09-2020 09:44 PM
for your case I would try to send a picture to see if my phone is the problem or if the problem was originally generated by the sender.
best regards,
Diyaa
04-09-2020 09:41 PM
are you using any app other than Massages to send your massage. for example, I had a problem like this before and I resolved it by using the massage application that was preinstalled on my phone by the manufacturer of the phone instead of Facebook Messenger or some others apps that you could install from the store. you should use the massage app that came with the phone ROM, because some apps tend to send the picture in different formats or pictures.
04-07-2020 10:15 PM
Make sure the data is on
04-07-2020 10:09 PM
Ok. How about clearing the MVNO fields. The rest should be fine.
04-07-2020 09:15 PM - edited 04-07-2020 09:16 PM
Is there a system (software) update that you can do for the phone.
04-07-2020 09:13 PM
@Dwhy Are you trying to add a duplicate APN?
Not sure why it's not working. If you can backup you contacts maybe worthwhile doing a factory reset and start over in the hopes that it will fix there issue.
Hope this helps.
04-07-2020 09:07 PM
04-07-2020 09:03 PM
04-07-2020 08:57 PM
@Dwhy leave the APN Type field blank or just enter internet,mms
04-07-2020 08:43 PM - edited 04-07-2020 08:44 PM
Try this. Select Public Mobile. Only for iPhone.
Will generate an APN file on your phone. Find it, install it.
https://www.unlockit.co.nz/fw/
04-07-2020 08:16 PM
I created a new apn and it said carrier does not allow adding APNs of type *
04-07-2020 07:30 PM - edited 04-07-2020 07:31 PM
@Dwhy wrote:
I can't take a screenshot because the screen refects badly. But here is the info
APN: sp.mb.com
Mms proxy: 74.49.0.18
Mms port: 80
Mcc: 302
MNC: 220
Apn type: default,mms,agps,supl,fota,hipri
Apn protocol: IPv4
Apn roaming protocol: IPv4
MVNO type: GID
MVNO value: 4D4F
@Dwhy Try this:
If you have data turned on it should work,all your other entries are correct.
04-07-2020 07:19 PM
APN: sp.mb.com
Mms port: 80
Mcc: 302
MNC: 220
Apn protocol: IPv4
MVNO type: GID
MVNO value: 4D4F
@Dwhy What happens if you leave Mms Proxy blank?
04-07-2020 07:11 PM
APN: sp.mb.com
Mms port: 80
Mcc: 302
MNC: 220
Apn protocol: IPv4
MVNO type: GID
MVNO value: 4D4F
04-07-2020 06:27 PM - edited 04-07-2020 07:36 PM
04-07-2020 06:15 PM
I would suggest that would be a minimum requirement. It's a lot like your home router where you set your devices to go through your router. Give it a whirl.
04-07-2020 06:11 PM
My mms limit is set to 1000
04-07-2020 06:10 PM
I don't have mmsc proxy! Is that the issue maybe?
04-07-2020 05:34 PM
@Dwhy wrote:Ok! I created a whole new apn using only the apn field and left everything else blank. Still not working 😞
Create an APN exactly as you see below:
04-07-2020 04:45 PM
Can you check your mms limit.
04-07-2020 04:30 PM
Is there an option called "Update PRL" inside your system settings? If yes, try that.
Also, you said data is on but to clarify, can you use data for internet?
04-07-2020 04:20 PM
04-07-2020 04:14 PM
04-07-2020 03:53 PM
@Dwhy wrote:The phone is suppose to be able to send and receive pictures and videos and when I spoke to the company they said it was the carrier not the phone
How old is the phone? Take it back to where you purchased it from if it's still under warranty.
04-07-2020 03:53 PM
@Dwhy try this
ACCESS MESSAGING SETTINGS:
1. From the home screen, select the Messaging app.
2. Select the Menu icon, then select Settings.
Here's a link to how to send / receive mms messages on an https://www.att.com/devicehowto/tutorial.html#!/stepbystep/id/stepbystep_KM1332393?make=Sonim&model=...
04-07-2020 03:52 PM
04-07-2020 03:49 PM
I was hoping that wasn't the case 😞
04-07-2020 03:48 PM
@Dwhy wrote:Yes
If you replied yes to my post, then it looks like your phone is the issue (perhaps hardware?) and not the MMS service.
04-07-2020 03:47 PM
Yes
