Picture messaging included in texts?
kennethmkelley
Hey all, hopefully a simple question here: Is picture messaging included in the unlimited international texts option?
10 REPLIES 10
@NICA wrote:
You do not have to have data enabled to send or recieve mms  I have turned mine off and I am still able to send & recieve mms & not on wifi either
This seems very unlikely. What phone are you using? What MMS app are you using?
This is MMS being talked about here...not standard SMS texting.
NICA
Tiptopssss
Should be fine with data set to ON
@kennethmkelley wrote:
Yes, I already have data turned on so we should be good there. 🙂
FYI, if MMS don't work for you, do not worry. Some phones require a proper APN settings for data and MMS.
popping
Enjoy your PM MMS messages.
kennethmkelley
popping
@kennethmkelley as mentioned that you need to enable data on your phone before you can send and receive picture text message.  Don't worry about the data charge used in sending and receiving picture messages as it is included with your text message feature in your plan.
kennethmkelley
Thanks to you both!
chrisbasm
@kennethmkelley- Yes it is.  However, you must have data turned on (on your phone), and your phone must be compatible & properly configured for data with Public Mobile.  You DO NOT need to actaully have a data plan with Public Mobile.
Dunkman
@kennethmkelley
Yes, picture messaging is included in international texts.  Make sure to turn data on. (even if you don't have data plan)
