05-19-2022 06:47 PM
05-19-2022 06:51 PM
Make sure your MMS (in messaging) and data are turned on
05-19-2022 07:06 PM
If you are talking about MMS, to get pictures in/out your DATA has to be set to ON. Data will not be used but it has to be on.
05-19-2022 07:11 PM
HI@Pawsregd Yes, you are talking about MMS. Make sure Mobile data is turned on to receive that.
No worry about the data usage from the MMS message , it won't count towards your monthly data limit. But if you don't have too much data, turn it off after you got the MMS message. If you leave it on , your other app might start using it
05-19-2022 11:46 PM
05-20-2022 12:56 AM
make sure you have the correct public mobile APN and/or MMS settings:
Public Mobile APN Settings for Android & iPhone 2022 - 3G 4G 5G LTE Internet Settings
Public Mobile MMS Settings for Android & iPhone 2022 - 3G 4G 5G LTE Internet Settings
05-20-2022 05:19 AM
You need to turn your mobile data on to accept messages that are pictures within a text (MMS) then turn it back off or it will continue charging you.
