Physical sim activation
lalcyphone
I changed from esim to physical sim. How to activate it
2 REPLIES 2
Dunkman
@lalcyphone
If you have eSIM installed and want to switch to physical SIM card, you don't need to "activate" physical SIM card.  Just need to change  your SIM card number in your self service account.  Do not try to activate a new account with physical SIM card.
Here is some additional information:
https://www.publicmobile.ca/en/ab/get-help/articles/change-sim-number
Once you change the SIM card number in your account, insert your physical SIM card in your phone.
golfball
You need to sign in to your account then go to the "Profile" section if you're on the website or the "Account" section if you're on the app and enter the new SIM card number to change it.
