03-17-2024 05:01 PM - last edited on 03-17-2024 05:14 PM by Dunkman
hi everyone, I would like to inquire about my order with my phone. Selected subscription is 50GB within Canada and the US data at 5G speed for $34. Account Name under xxxxx xxx xxxx with account #…..2181 and I didn’t receive my physical Simcard. Instead of physical SIM card, will you be able to process it via eSIM. Looking forward for your help and thank you in advance.
How do I get a Ticket ID#?
Edit by Dunkman: removed personal information
03-17-2024 07:26 PM
Hi @Fidel4
Another option would be to buy a Public Mobile physical sim card for $4.99 at Amazon. With Prime delivery it is quite fast...
Link: https://www.amazon.ca/Public-prepaid-postpaid-Activate-Allinone/dp/B06X9ZGDWG
03-17-2024 05:07 PM
Only if your phone is eSIM compatible.
What phone do you have?
03-17-2024 05:06 PM - edited 03-17-2024 05:07 PM
@Fidel4 Your posting to a community of customers like you trying to help . Instead please
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send private message to support .
send a private message To CS_Agents
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
03-17-2024 05:06 PM
HI @Fidel4
sim delivery can be as fast as 5 days or as many as 3 weeks. One way is to get it faster by buying a PM sim card from telus/Koodo store. But yes, you can also change to eSIM. Please check with CS agent for this request. please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
