Duplicate payment
Johnyi
I was charged twice on February 2nd and 4th for the amount of $20.16 on my Visa. Can you rectify this problem?
1 REPLY 1
HI @Johnyi
first login My Account and check payment history, does it show one or two amount for $20.16?  and did you make any plan change and manual payment that 2 days? check Payment history, any hint it shows Available Fund of around $18 after Feb 4th?  Maybe you can post all the transactions from Feb here so we can help?
or if you like CS agent to help, submit ticket.  please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
