Downloads
03-06-2024
05:00 AM
03-06-2024
07:56 PM
computergeek541
I am unable to download picture attachments even with my mobile data on. Any idea why that is? Am I overlooking something?
Phones
03-17-2024 07:39 PM
HI @Bozoo
Nokia 6.1 was only from 2018, not too bad
To resolve the MMS issue, there might be a bit more work then simply updating. Many confirmed that you need to delete the current APN profile first. Then Add new profile and add according to this, please note case-sensivitve and do not add extra spaces. Remember to save the new APN and then reboot the phone before you try
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
(might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
03-17-2024 07:38 PM
Hi @Bozoo
did you try Reset All Networks?
03-17-2024 07:31 PM
It's a Nokia 6.1...a dinosaur.
03-17-2024 07:18 PM
HI @Bozoo
what model of Nokia phone is that?
03-17-2024 07:15 PM
I think my Android phone is not being supported by Nokia anymore. Because I tried all that was suggested and still can't download pictures. Thanks for all your suggestions. It's appreciated 😌
I guess I'll be asking for a new phone for Christmas! For now I'll have to accept I won't get pictures downloaded . Oh well...
03-06-2024 10:57 AM
Thanks!
03-06-2024 06:14 AM
Might likely also be related to this @Bozoo :
03-06-2024 05:19 AM
Thanks, I'll try that.
03-06-2024 05:07 AM
Try resetting the Network settings. If that didn’t work then check the APN settings on your phone.
Here are details on the APN settings:
