a month ago
Scan of QR code doesn’t work and app says can’t install eSIM so contact support but when I enter a service ticket the submit button is greyed out. My number was transferred from Fido through the text fine. So now without any phone service.
Someone please help!
a month ago
@Redhot you checked Settings -> Cellular and confirm PM sim is not there?
Try send PM a message. Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
a month ago
Like I said in my post. I can’t submit a ticket it’s greyed out on chrome and safari. Can’t submit a ticket.
a month ago
iPhone 17 pro max
a month ago - last edited a month ago
@Redhot wrote:Scan of QR code doesn’t work and app says can’t install eSIM so contact support but when I enter a service ticket the submit button is greyed out. My number was transferred from Fido through the text fine. So now without any phone service.
Hello @Redhot - If I may ask, which phone are you currently using? Before you contact customer service though the link provided, let's see if the community can try to help first. That's why we're here! 🙂
a month ago
hi @Redhot
if you need PM agent to help, use this link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
please use the same Community account login you are using now to login and submit ticket
