Phone
04-29-2022 10:32 AM
04-29-2022 02:12 PM
04-29-2022 01:14 PM
working service ?
or
phone is dead
04-29-2022 12:23 PM - edited 04-29-2022 02:11 PM
04-29-2022 10:49 AM
@Italy wrote:I paid yesterday and it was cut off 20mins ago
@Italy - when you log into your self serve account does it say ACTIVE? https://selfserve.publicmobile.ca/
Or, what does it say when you call 611 for status.
If your renewal was today, perhaps you are in the bewitching hours...although you should not lose services during the renewal process, it has been reported to happen. Is your renewal today?
04-29-2022 10:49 AM
Can you log into your self serve account? How did you pay? Voucher? Credit card? Autopay?
To pre-verify your account include in your private messaging only your full name, address, email, phone # and 4 digit acct pin #.
04-29-2022 10:48 AM
Can you log into self service or call 611 from your phone to let us know whether your account is in active status? What plan are you on? Did you port a number over?
04-29-2022 10:46 AM
This is the phone company you can't phone. So no one will call you. Just look at it as instead of talking you're typing. You still have to pass the same info along to get the help you need. Just nothing personal or financially sensitive.
04-29-2022 10:45 AM
04-29-2022 10:43 AM
@Italy wrote:I need some one to call me ASAP
Public mobile customer service is all online. There is no phone number to call unfortunately. As stated before, more details would be helpful.
04-29-2022 10:42 AM
PM has no live support. All support is trough email. But before you send them a note or open a ticket, describe your problem and we will try to help you out.
Only account issues are handled by PM staff.
04-29-2022 10:41 AM
We would need way More details.
Is it powering on at all? Do you subscribe for PM services?
What is actual issue?
04-29-2022 10:39 AM
04-29-2022 10:39 AM
04-29-2022 10:38 AM
My phone has not working
04-29-2022 10:37 AM
Sorry to hear about your troubles. To help further, we need further details.We are all customers like yourself on this forum.
Are you a new customer? ported over your number? Is your account status active or suspended?
More details the better.
04-29-2022 10:36 AM
@Italy - what more can you tell us... Are you even a Public Mobile customer yet, did you activate a SIM card through the activation process and was charged for the activation?
Some troubleshooting to try unless you can provide further info.:
*turn off your phone, then reboot
*removing your SIM, then reinserting it
*go into airplane mode, then going back to regular mode
*perform a reset network settings on your device
*try your SIM card into another compatible phone for a few days to see if the issues are the same...this could rule out a device issue/setting.
*manually select the 3G / WCDMA ONLY network in your Mobile Connections area in your settings (temporarily) for dropping or unable to make incoming/outgoing calls
*Is your phone locked? Contact your previous provider to unlock it for you. You will need your imei number, dial *#06# to get it.
*Check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
