06-11-2020 06:16 PM - edited 01-05-2022 11:39 AM
06-11-2020 06:41 PM - edited 06-11-2020 06:43 PM
@LT1 use this link to start a private message
if you use SIMon you will have a faster response time. all you have to do is tap on the chat bubbles then tap "submit ticket, click me"
06-11-2020 06:40 PM
Tried Simon Useless! I tried to access my SIM by punching in my code It ;ocked me out after 3 tries. Then asked me to contact carrier for PUK code
06-11-2020 06:21 PM - edited 06-11-2020 06:22 PM
@LT1 if this is the first time you put your PM SIM into the phone and it asked for a SIM unlock code. Then your phone is locked to your previous provider contact them and ask them to unlock it for you. You will need your imei number dial *#06# to get it.
On the other hand, if you locked yourself out. Then contact the moderators and ask them to for your puk code. There are 2 ways to contact the Moderator Team:
- Faster response- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
- Slower- Alternatively, you can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work.
Keep an eye on the envelope top right of your screen. The mods answer will show up there. Stay safe.
Welcome to the community.
06-11-2020 06:21 PM
@LT1 if the PUK code is 8 digits long you can contact customer support here
https://www.publicmobile.ca/en/bc/get-help/articles/contact-a-moderator
make sure to check your inbox(top right corner envelope icon) periodically, for a message
Moderators are available from Monday to Friday from 8AM to Midnight EST and from Saturday and Sunday from 8AM to 10PM PM EST
06-11-2020 06:19 PM
@LT1 hi what is the message that you are getting did you just sign up is your phone locked there are are a couple of possible puk messages
06-11-2020 06:19 PM
@LT1 wrote:Can’t access my SIM. Need PUK code
First off, we need to know which type of PUK you need.
There is one that is security feature specific to the SIM card (a mdoerators needs to give you that).
There is another called the SIM Network Unlock PUK. That means that your phone is locked to another carrier (the carrier that the device is locked to or the manfuactuer would be needed to help you).
What's the exact on-screen message?
