04-15-2020 12:31 PM - edited 01-05-2022 11:39 AM
Is there a plan for 10$ per month now?
04-17-2020 01:26 AM
@helenhelen wrote:Wait a minute.. so you can do an add-on at any time in the middle of a billing cycle? And then remove it right away for the following one?
It's rather more helpful to indicate who you're replying to.
Yes you can buy an add-on any time and it starts right away.
No you can not remove an add-on. Why would you? It's a buy once, use over time thing.
04-17-2020 01:21 AM
04-17-2020 01:19 AM
The data plan is pricey considering it is only 1GB and you get nothing else. Would be cheaper to go with the $25 plan and get 1GB if you do autopay, plus get actual phone service too.
04-15-2020 01:28 PM
It is a great emergency plan and many are hoping it will be back.
Changing plans is very easy, if you don't find anything else that suits you from competitors I suggest you take $13(15-2) plan, it is only $5 more but you do get much more, and if we are ever lucky again to have $10, the switch is literally 3 clicks away.
Probably worth mentioning is that every year your 'monthly' bill goes down by $1 and the $15 plan will eventually be $8 worry autopay and loyalty (yes $10 plan had potential of being 3 or even less with referrals)
Welcome to public mobile
04-15-2020 01:01 PM
Sorry that plan is discontinued last fall unfortunately.
I have seen people selling them on Craigslist and kijiji, some of them with loyalty or referrals so that there cost down to $5 per cycle
04-15-2020 01:00 PM - edited 04-15-2020 01:00 PM
@qingming wrote:Is there a plan for 10$ per month now?
There's a free voip app that will let you place free calls to North American numbers and free texting as well. As long as you have wifi, TextNow is a good alternative. ..but I'm sure there's other apps as well. I can vouch for TextNow as I've used it for a couple of years now.
Stay safe, stay home and plan your next vacation.
04-15-2020 12:59 PM
@ddeep91 wrote:
It is better than the $10 plan PM had in the past as this one will have
Depends on what your needs are. I don't want to be obligated to pay more. If I use more than 50 minutes then there are the add-ons to go over on. If I send more than 50 texts then there are apps like TextNow to go over on. Data add-ons are fine especially now with the pandemic offer. I like that the add-ons just hang around until needed.
04-15-2020 12:59 PM
super weird I didn't see any replies now I see like 5 above mine???
04-15-2020 12:58 PM
The cheapest current plan is $15.00
Check out the plans below.
https://www.publicmobile.ca/en/on/plans#plans-start
04-15-2020 12:55 PM
Nope, that's long gone
The cheapest plan would be starting at $15 - With a $2 applied for setting up AutoPay.
It will cost $13+ Tax/ month for the cheapest plan with PM!
- Unlimited incoming calls
- 100mins outgoing calls
- 250mb - With autopay
Cheers
04-15-2020 12:37 PM - edited 04-15-2020 12:38 PM
04-15-2020 12:37 PM
@qingming The cheapest one is $15 for now. Who knows, maybe PM will return the $10 plan some day. To my mind, during this pandemic, this would be a good move from their side, especially because many people I know lost their jobs, or their salaries were decreased, so they look for better deals now.
04-15-2020 12:36 PM
That plan is no longer being offered. You could setup autopay with a Visa debit or credit card and save $2 plus get three friends or family members to get $1/referral to lower your cost.
04-15-2020 12:32 PM - edited 04-15-2020 12:34 PM
04-15-2020 12:32 PM - edited 04-15-2020 12:35 PM
@qingming Hi no sorry it is no longer available Some of us are hoping it will be brought back especially in these times were people just need a phone for occasional use as in an emergency
