02-23-2023 11:54 PM
02-24-2023 05:53 AM
After you've secured another device:
Get SIM card
Try a corporate TELUS, Koodo, or Mobile Klinik location Mobile Klinik locations
Alternatively, if in the GTA, there’s Canadiancellsupplies
Contact them in advance to ensure they have PM SIM cards in stock.
Changing SIM card
In order to change the SIM card associated with your account, you must now verify your request through a one-time security code that will be sent via SMS or email. To change your SIM card, please follow the below steps:
- Log into your My Account
- Go to Plan and Add-Ons > Change SIM Card
- Enter your new SIM card number
- Select where you would like your 6-digit security verification code to be sent to. You can choose to have the code sent to your email, or via SMS to your phone number. If you do not have access to your phone or cannot receive SMS, please select the email option.
- Check your email or phone for your security code, and input the code into the page
- Click “Verify Code”
Please note: after 5 failed attempts to verify your security code, your account will be locked, and you will need to have your account unlocked and your SIM card manually updated by an agent by submitting a ticket.
- Once you have verified your code, click “submit” to complete your SIM card change.
02-24-2023 12:07 AM
couple things you should do
Try to "find" your phone to remote wipe
Apple: https://www.apple.com/ca/icloud/find-my/
(how to use: https://www.pcmag.com/how-to/find-a-lost-iphone)
Google: https://myaccount.google.com/find-your-phone
Samsung: https://findmymobile.samsung.com/
(how to use: https://www.pcmag.com/how-to/how-to-find-a-lost-android-phone)
Login to My Account and suspend the service using Lost/Stolen
Login to My Account, click Quick Links on top right and then click lost/Stolen phone
Buy a new sim card and tie your number to the new sim card
Get a sim card from local Telus or Koodo store or get it from Amazon:
(Please note if you order the sim from PM online, it could take long to deliver, as many as 3 weeks)
Once you got the sim card, go to My Account from ONLY a desktop or laptop computer to request Change Sim card (please note that due to some glitches, accessing change sim care from mobile phone or tablet won't work)
After you logged in, unsuspend first if you have suspended your service earlier.
Then click Quick Links on the top right and select Change Sim card and follow the steps:
https://selfserve.publicmobile.ca/en/account/edit/your-account
02-23-2023 11:58 PM
Buy a sim, log in to your account, use the change sim function, insert sim.
