10-27-2022 01:27 PM
I want to upgrade my iPhone 7s to and iPhone 11. Do I need a New SIM card?
10-27-2022 01:51 PM
@Anter You only need a new SIM card if you are having problems with your signal/service or if you have an iPhone 4S or lower.
10-27-2022 01:44 PM
@Anter No, you don't need new sim card.
10-27-2022 01:35 PM
No. You just have to watch if SIM card sizes are the same and use appropriate adapter if needed.
Then there is something with Apple ID or whatever to handle.
10-27-2022 01:34 PM
@Anter wrote:I want to upgrade my iPhone 7s to and iPhone 11. Do I need a New SIM card?
You can continue using your current SIM card. Both phones use the same size of SIM card.
