08-20-2022
02:21 PM
10-27-2022
05:13 PM
computergeek541
Before I change my $35 plan to $25 I wanted to make sure that any "promotions" I have wont be deactivated or lost. I got a few Christmas time deals over the years as free add-ons and don't want to loose them. Will they be gone when I change plans? I'm trying to "heed" the warnings now so I'm not angry later.
Cheers
10-27-2022 02:15 PM
08-20-2022 02:30 PM
@tmeminem wrote:I feel I can safely presume that before changing in the big white boxes under the change plan if I had promotion it would show what it was? If nothing, blank box.
Not sure what you see, so I won't yeah or nay it @tmeminem .
If you only have xmas addons, and addons you purchased yourself than those will all stay on your account.
Would you like to provide a screenshot of your addons/promos to have a look (no personal info. though please)
08-20-2022 02:27 PM
You will Not lose any Christmas bonuses nor your rewards. They are associated with your account not Plan.
BUT if you have any promo associated with particular Plan (xGB for 6 months when signed up with Plan XY) then you might lose that.
08-20-2022 02:26 PM
08-20-2022 02:25 PM
if you have use when you activated this promo code: 2GBBONUS then you will losing when you change plan, for other promo or rewards they will keep as is.
use browser from computer,and clear cache and cookies and use one page inPrivate mode,
To Login Page
and go to Plan & Add-ons, and scroll the plans using the down and up arrows on the far right. select the plan you want, and select ‘Change plan now’ then you pay full price plan, or ‘Change plan on renewal date’..to you not losing any money..
08-20-2022 02:24 PM
All the xmas freebies from public will stay with you whenever you change plans, so no worries there @tmeminem .
Warnings are just standard, in case you had a activation promo that was tied to your current plan.
08-20-2022 02:24 PM
@tmeminem Any holiday gifts from PM or purchased add-ons or loyalty/RAF/autopay rewards will not be affected by changing plans, although rewards will not get applied if choosing to Change Now instead of at Next Renewal (recommended option) as PM doesn't prorate either.
Any activation promo data could be lost depending on the terms and conditions for that promo.
08-20-2022 02:24 PM - edited 08-20-2022 02:24 PM
You won’t lose your bonuses but if you are on a 2gb data for 12 months with a minimum $35 plan then you will lose it because $25 plan is less then the minimum requirement.
