Phone transferred number
Acidburn420
So I transferred my number successfully I can make calls out but can't receive calls
14 REPLIES 14
@Acidburn420
then it is a porting issue.  the port was NOT completed.  Please call the porting support team to confirm the status
Acidburn420
I can make calls out however I cannot receive calls it says I'm connected to pm network and able to use lte but like I said I cannot receive calls
@Acidburn420 wrote:
The customer you are calling is unavailable call again later but I'm able to call out and use data
HI @Acidburn420   can you call out or can you not?  On your original message, you said " I can make calls out"
Whether you can make call out really make a difference, please confirm.  And check if your phone showing connected to PM network
pmbc
@Acidburn420  definitely get it checked out then.
Acidburn420
It's been 19 days
pmbc
@Acidburn420 how long has it been since the port?  Some ports can take up to 24hrs.  If it's been longer, then yeah give the port team a call at the number that's @Chalupa_Batman has sent to you.
Acidburn420
When I restart nothing changes I also took out and placed back in Sim card
@Acidburn420  look at the top right corner of the page. You'll see a message.
Acidburn420
pmbc
@Acidburn420  May seem basic, but have you tried to restart your phone?  What happens when you try to call yourself from another phone?
I have a feeling the port over may not have fully worked. I'm going to send you the porting number to reach out and fix this issue. However, first, because you tossed your old carriers SIM card, reach out to them first to confirm your account is active or closed. If they say it's active, then call the number I'm sending you. If it's closed, I'll provide a link to reach a CS Agent to help fix.
Acidburn420
I shot old Sim in garbage it's been almost 19days I just realized I wasn't getting g phone calls only making them and my data only works with 5g vand off
Chalupa_Batman
Hey @Acidburn420
Quick question. If you put your old providers SIM card in the phone, do you still have service on it or is it SOS?
Acidburn420
Also 5g has to be turned off for my data to work I have a 5g plan and phone though
