01-25-2020 11:32 PM - edited 01-05-2022 09:11 AM
If I take my phone across the border to the US without a roaming plan, what will happen? If I try to make a call what happens. What about texts? Can I order roaming from the US?
01-26-2020 07:25 AM
If you have access to wifi then you could use apps like WhatsApp, Skype, Fongo, and Textnow.
01-26-2020 01:49 AM - edited 01-26-2020 10:53 AM
I've received texts in the US without a roaming plan but I am not certain that you could count on receiving all all texts sent and it may vary with what provider you are hooked on to and what area you are in while in the US.
AE_Collector
01-25-2020 11:52 PM
@geopublic wrote:
@turky wrote:If I take my phone across the border to the US without a roaming plan, what will happen? If I try to make a call what happens. What about texts? Can I order roaming from the US?
@turky If you try to make a call it will not work. You might be able to receive a text (unofficial) but you will not be able to send one.
Yes you can purchase a US roaming add-on when you are in the US.
I had heard that you would receive texts without a roaming plan but have not been able to test it.
01-25-2020 11:50 PM
Thanks for that
01-25-2020 11:36 PM
01-25-2020 11:34 PM - edited 01-25-2020 11:35 PM
Nothing will happen it won't work.
You can add a add-on plan through your self serve account.
note once bought it starts right away.
Two steps to buy an add-on..guide below.
https://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/HOWTO-Purchasing-Add-ons/td-p/198974
