01-26-2020 12:58 AM - edited 01-05-2022 09:11 AM
01-26-2020 12:25 PM
@Maggilynnd wrote:You'll also get text message notifications at 50% 75% and 100% of data used!
I've found that if you have a data add on, such as the the holiday 1GB add-on, you do not get any of these text notifications when your BASE data allotment reaches these thresholds.
For example with a 250MB base plan + 1024MB holiday add-on, you will be unaware of your 250MB getting used up unless you're paying close attention to the usage in the self serve portal. I presume you'll get alerts when the 1024MB add-on is reaching those thresholds...
01-26-2020 06:18 AM
01-26-2020 01:11 AM
Thank you so much,very helpful information.
01-26-2020 01:06 AM
@Bridgette Another option is to use your phone's data usage built-in app to track your data usage. Set the start date to be the same as your plan's start date. It is pretty accurate and give you a good idea on how much data you have used up.
01-26-2020 01:01 AM - edited 01-26-2020 01:04 AM
Log into your self serve account and scroll down to "My Data and add-ons" it will display there...if it does not display there that means you used up all your data.
Welcome to Public Mobile 🙂
