03-16-2026 06:40 PM
Hi there, I switched my wife's phone over to Public. Her phone was successfully transferred over, exepct her phone has been on SOS for quite some time. Is there any way we can get this fixed soon? She has an iPhone11 Pro Max, we have a Public SIM card in it.
03-16-2026 07:03 PM
Had to put in the old carrier SIM and accept the transfer services text. Approved it and now the public SIM is working. Thank you!
03-16-2026 06:44 PM
hi @Wayner15
so, the old carrier sim is no longer working? you removed the old carrier sim yet?
Reboot the phone and click Reset Network Settings
if same, ask PM agent to check and helpy, you can submit ticket by direct message:
03-16-2026 06:44 PM
Hi there,
Old SIM has been removed and phone is not compatible with eSiM. Network has been reset, still getting the SOS status.
03-16-2026 06:42 PM
Make sure you removed the old sim card and disable the old esim. Then Reset Network Settings after a device reboot
But if you still see SOS, ask PM CS agent to re-provision the account
Private message CS Agent at:
