03-15-2023 01:20 PM
I’m trying to get an old phone number I use to have switched over. Is that possible or can I create a custom phone number? Thank you
03-15-2023 01:24 PM
@Moo94 You won't be able to retrieve an old number you used to have. You will be presented with a selection of phone numbers to choose from when you create a PM account. So it's not custom per se, but you can keep going through a list of numbers that they present to select the number you want.
03-15-2023 01:24 PM
You can port your old number to PM.
BOTH accounts have to be active.
Log in to your PM account and do transfer number.
Keep old SIM in your phone. You will receive SMS from old provider and you have to reply YES within 90 min to authorize transfer.
You cannot create custom phone number.
If you are new customer I suggest to activate account and pick ANY number. When service is stable do transfer.
03-15-2023 01:23 PM - edited 03-15-2023 01:24 PM
Yes you can by porting your old number over from another carrier and NO to the custom number. You can only pick what number is offered while activating the SIM.
Also, you old carrier account must be active to port over your number. If it is cancelled then you can’t unless it is a Telus or Koodo account.
