Phone number transfer
03-10-2024 11:55 AM
03-10-2024 01:16 PM
Hi, simple steps are:
-buy a PM sim card on Amazon
- install PM app in your phone
- login to PM app or create login info
- in the app, under Myaccount, hit the +🎯 and go to profile, under profile scroll down and choose Transfer phone number. Complete the process when on WiFi and when keeping inside your old SIM card
03-10-2024 12:05 PM
Do you mean transfer phone number???
You just have to initiate transfer at Bell side, keep bell SIM in your phone, reply Yes within 90 minutes. All done. Wait 2-3 hours and plug in PM SIM. Confirm service is working.
03-10-2024 12:05 PM
if you’re referring to two factor authentication from certain merchants or institutions, you may find those may take a few days to transfer over when you port a number from one mobile service provider to another.
The reason for this is security-related to prevent authorized use of your number as a 2FA code of accessing an account or service.
03-10-2024 11:58 AM - edited 03-10-2024 11:58 AM
@brodood I'm not sure what you mean by Bell phone codes, are you joining Public Mobile and want to transfer your Bell phone number? This can be done after or during setting up your Public Mobile account, or have you tried and run into a problem. Can you give more details please?
