10-03-2023 06:56 PM - edited 10-03-2023 06:57 PM
Hi,
I'm trying to move my phone number to PM, and I guess I must have mistyped my IMEI. I got the text from my old provider confirming the move (to which I replied YES), but then a text from PM saying I had entered in my IMEI incorrectly, and that someone would contact me shortly. Is there a number I can call to get it sorted out?
11-17-2023 10:28 AM
Good Day! Im having the same issue as hypertech did a couple weeks back. Need that number to get the post sorted out. thanks.
10-03-2023 07:01 PM
Awesome, thank you
10-03-2023 07:00 PM
call the porting support team. I will send you tje number to your Community inbox.
10-03-2023 06:59 PM
There is a number to call to talk to live support, you can update them with the proper account number instead of IMEI. They can re-trigger the process for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
