05-03-2024 10:39 PM - last edited on 05-04-2024 01:26 AM by computergeek541
Every time I try to log in to my account it sends the 2fa to the previous number before I ported my number and now I can’t login to contact support. What do I do?
05-03-2024 10:42 PM
Try using email address to receive the code and see if that works
On the screen it is expecting you to enter the code, click Didn't get the code? or Resend code and then choose Send email
If it does, after you logged in, go to Profile page, click Manage EverSafe ID and update the phone number there
if you cannot login still, then ask support agent to help to update the phone number for the 2FA code.
05-03-2024 10:41 PM
@Tt10 , did you try resend code which gives you option of receiving the code to email? It is unfortunate that the eversafe ID does not auto populate the phone number after a number port. So, once you do establish account access, make sure to do the phone number update.
