Phone number change
Virat
I changed my number (stayed with public mobile only) but I am not able to call or receive the incoming call. I can send the text message though but could not receive a text message. When my services will start?
HALIMACS
@Virat
Do you mean you switched providers from another mobile provider to public mobile, and you also wanted to move your prior phone number here?
If so, did you reply "YES" to the port authorization request from your old provider?
If not, to re-initiate the port, click here: https://urlshortner.tiia.ai/Lc9xk8
Then, make sure to place your prior provider SIM card in device, await text for port authorization, reply "YES", then replace with your newly activated Public Mobile SIM card.
Reboot your device, and you should be good to go.
darlicious
@Handy1
Set to telus? What are you saying?
@Virat
Did you activate and port your phone number in? Or change your phone number? Can you confirming you have the following services working or not?
  1. Calling: In?  Out?
  2. Texts: SMS: in?  Out?  MMS: In? Out?
  3. Mobile data: Yes/No
Do you see Public Mobile at the top left of your phone's home screen?
@Virat @You can try to reset your network setting aswell and make sure it’s set to public mobile … if you need more help you can always talk with agent too
Getting help from agent , through automation
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get started.
Or  get direct help from a agent right here in the community ( my preferred choice )
  • Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work
Did your restart your phone after changing the number
