06-25-2022 05:45 AM
My phone account was suspended for a month for non-payment. Made credit card payment yesterday. Phone is still not working. When I tried to sign up for reward it said, my email and phone number do not match?
Could my phone number have changed?
06-25-2022 10:59 AM
06-25-2022 08:55 AM
Have you registered for a Self Serve/My Rewards account yet?
If not, you can here https://selfserve.publicmobile.ca/self-registration/
But if you are in suspended status, you will need to be in Active status to register for one.
Do you have a card registered to your account? If so, call 611 to make a payment or obtain vouchers to get your account active: https://www.publicmobile.ca/en/on/get-help/articles?q=vouchers
06-25-2022 07:38 AM
@BigO wrote:My phone account was suspended for a month for non-payment. Made credit card payment yesterday. Phone is still not working. When I tried to sign up for reward it said, my email and phone number do not match?
@BigO How did you make the payment ? Via My Account or via *611?
Try one more reboot of the phone and see if it works
If not, Login to My Account and check if the account status still showing Suspended. And check if the money you paid is sitting as Available Fund. If so, you can try to make an extra $1 payment, this should trigger the account to reactivate
For My Rewards, there is no sign up needed. My Rewards site takes the same login as My Account. I assume you already have My Account access, so just use the same email address and password you used on My Account to login to My Reward
06-25-2022 07:26 AM - edited 06-25-2022 07:27 AM
I can't imagine your phone number changed - to test this, try calling your number from another phone to see if it still goes to your voicemail.
After you made payment, did you tap "resume" service under the self-serve account? Also, ensure the payment went through by checking under the payment card transactions.
Try logging into your self serve account to see what is listed as the status of the account. While there, also check the "View Payment History" section in self-serve to ensure the payment was applied to the account.
If account status is listed as "Active", reboot your device and reset network connections to see if that helps.
