Phone not working
09-26-2024 10:21 AM
I have debit preauthorized for payment. It is due today. Has not been taken out. Phone not working
why?
Service
09-26-2024 12:32 PM
you can reset your PIN using this link
09-26-2024 11:55 AM
Hey @Sebastian5,
Only you know the PIN of the phone, we do not have access to your phone security information.
Please send us the phone number and the SIM card serial number so we can check that out for you!
Oana 🙂
09-26-2024
11:45 AM
09-26-2024
04:08 PM
computergeek541
I HAVE TRIED ALL NOTHING IS WORKING
WHERE DO I FIND MY PIN FOR PHONE PAYMENT NEED IT RESET
09-26-2024 11:21 AM
do you mean account pin or you meant sim pin?
did you try login My Account using Incognito mode and make a payment there?
09-26-2024 11:19 AM
I have rebooted not working. what is my pin to do it on phone how do I reset pin
09-26-2024 11:03 AM
To avoid occasional autopay failure I would suggest to manually add funds with registered credit card. That way you KNOW renewal will work as payments go from available funds first then credit card.
At the same time, when adding funds, any issue with card or payment could be discovered and immediate action (ticket) taken.
09-26-2024 10:28 AM - edited 09-26-2024 10:29 AM
many autopay failures this week. Login My Account again using Incognito, make a manual payment by clicking Pay and Resume services. If payment is made successfully, reboot phone after 2 mins
but if you still cannot make payment due to any error, buy a voucher to make a payment. You can get it from stores and load using *611
09-26-2024 10:23 AM
HI @Sebastian5
sometimes it just needs a reboot. Try reboot the phone once. Check if it connects to PM and if any of voice data work
if same, please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
