02-06-2025 11:43 AM
I tried to change phone number, and add a plan. Now my phone is not in service?
02-09-2025 12:12 AM
02-06-2025 04:17 PM
I had the same issue but with porting. I had to get PM to resend the port request to approve it again, did it a total 3 times until it finally worked.
Message cs_agent to get them to send another request and make sure to keep the old SIM in there to approve the port, before adding the PM one back in
02-06-2025 12:16 PM
Do you mean change number and switch to a new plan from old plan?
If so then reboot your phone by powering off then back on.
If you opened a second account under the first account using the same email address. The second account will replace the first account. You can only have 1 account/1 email address.
If this is the case then you need a CS_Agent to straight things out for you.
02-06-2025 11:47 AM
hi @TanyaMarie
"add a plan", if you meant you need another line, you need another email address to setup a new account as PM does not have family account.
no worries, support agent can sort it out and give you back the old number. Please submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
