Phone doesnt work
JulieD2
Hi, i change my credit card number last month, and 2day i can make a phone call. So i reenter my new credit card to be sure and i see the payment was preautorise... but didnt have my phone line yet!
2 REPLIES 2
HI @JulieD2   you are not alone, there are quite some posts with calls problem.  It is not affecting everyone but definitely many
please open ticket with CS agent and see if they can confirm any outage:
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
@JulieD2   it likely not a payment issue but some trouble on PM side
 is that just outgoing calls with the problem?  are incoming calls working?
There have been issue since yesterday for some people with both incoming and outgoing calls.
If it is just outgoing calls with issue, try to reboot the phone once.  If still fail, try to change to 3G only and see if it connects to the network at all with such settings
If both incoming and outgoing calls are not working, I suggest you to open a ticket with PM support and let them aware you are one
Please open ticket with PM support using Chatbot:
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
