[Megathread] No Incoming / Outgoing Calls
Shananahan79
Neither my husband or I can place or receive calls, but everything else works. Anyone else?
283 REPLIES 283
widespread voice call issue.  I think data still work.
if you like, download a VoIP app like TextNow and use it to make calls until issue is fully resolved
hi @Blujay
yes, network issue
there is a big thread about the voice calls
try Reboot the phone, or you might need to wait PM to fix the issue
@Blujay
this has been reported and affects customers in Ontario and points east. Should be fixed soonly.
Blujay
I am unable to receive or make calls in Whitby, Ont. Is there a service outage?
@Smitti
you're right...this has been reported and affects customers in Ontario and points east. Should be fixed soonly.
hi @Smitti
@GS11
There was reports of outages in BC, Alta. and Ont. yesterday.
Please check the outage map for your area:
https://www.telus.com/en/bc/outages
Smitti
Appears to be no incoming/outgoing telephone calls since about 10:00 am . London ,Ontario
hi @GS11
yes
@GS11
GS11
Network down?
Fridge1
thank you!
BrittanyGail
This issue is also effecting New Brunswick
it seems.
@Fridge1
Fridge1
my payment are up to date. i cannot make calls nor text.
hi @Ayala18
@Ayala18
@Daytona93 wrote:
I try and make a call, and nothing happens. No message or anything. My texts are working still.
You're likely in Ontario or somewhere east of Ont. There's a network upset right now, should be fixed soon...we hope.
Ayala18
My plan was renew
i can get phone calm and data is working but can’t pass phone call
Kith
 's suggestion of putting the phone into airplane mode for a minute or so and then turning it off worked for me. Worth giving that a try!
Kith
@RickCamilleri 's suggestion of putting the phone into airplane mode for a minute or so and then turning it off worked for me. Worth giving that a try!
Daytona93
@Riprogers_29 wrote:
tried to see if there were any issues, first time using this, Thank you
Keep watching the Community for updates. Also, try a call every 30 mins or so. Let us know when your calls are normal again.
Daytona93
I am having the same problem. Hopefully it is resolved soon.
Robophono1
Yes, same here. My mom, spouse and I are all on PM and none of us can make calls this morning.
Riprogers_29
hi @
