Phone deactivated
Randallb57
Why has my phone been deactivated while traveling through the USA? My account is in good standing.
VIP_Tech
Hi @Randallb57
if your account Status Active, then you need to purchase 10 day U.S. Roaming Package to you can use the service in U.S.
How To Purchasing Add-Ons using your Self-Serve account (publicmobile.ca)
after purchase successfully, Reboot device.
Yummy
Do you mean your phone is not working while being in USA?
If you account says 'active' then your PM phone is in good standing and should work while in Canada BUT if you did not buy US add-on(s) then you will not have service while in US
US Roaming for 10 day packages
Unlimited U.S. Talk, Text and 250MB Data Bundle = $20
Unlimited U.S. Talk and Text Bundle = $15
Unlimited U.S. Talk Only = $8
Unlimited U.S. Text Only = $8
U.S. Data Only for 10 day packages
250MB = $10
500MB = $15
1GB = $20
@Randallb57
There no Telus towers in the USA but if you purchased roaming, PM will switch to AT&T or T-Mobile towers to make your calls.
Dunkman
@Randallb57
Did you purchase a 10 day US roaming  package while in the USA?
Is your account status active or suspended?
You should be able to receive texts while in the USA without a roaming package.  Otherwise, other services like call, data and outgoing texts needs a 10 day roaming package.
@Randallb57 do you have no service in USA or your account got deactivated?
you need to buy US roaming addon to use the service is USA
