02-14-2023 05:07 PM - last edited on 02-14-2023 05:09 PM by computergeek541
Hi does anyone use a Samsung 21+ with public moblie. Mine is unlocked but it doesn't seem to be compatible. Currently I have the sim in a Lg stylo 6 and the sim works fine. I'm wanting to use my 21+ if possible. Is public moblie compatible with only cheaper phones? 🤔 Do you recommend me going into a telus store and ask for help?
02-21-2023 06:35 PM - edited 02-21-2023 06:45 PM
@jd444 so, it is not connected at all? Try to factory reset with your PM sim card inside once
If still does not work, try to ask for a friend with Koodo sim or Telus sim to see if it works
If nothing works, time to check your Samsung warranty to see if you can send it in for repairs. I kind of remember a similar case before and ended up Samsung cannot find the root cause and have to replace the phone
Add: you are certain that the PM sim card was ro on another phone?? just in case it is a faulty sim
02-21-2023 05:51 PM
Does not connect to PM network for some reason and ive called Bell to see if the phone is unlocked, which it Is. So im very confused at whats happening
02-14-2023 06:50 PM
you can call bell or Samsung and they will unlock the device for you
02-14-2023 06:13 PM
HI @jd444 S21+ from Bell would definitely work on PM. My friend had one from Bell and using it here too
what exactly not working? voice or data? or it does not connect to PM network?
02-14-2023 06:08 PM
@popping wrote:Create a PM support ticket to ask CS Agent to send you a PM configure file.
Even if agent sends him 'config file' how is he suppose to apply it?
02-14-2023 05:29 PM
@jd444 if you have not done that yet, have the PM sim card inside perform a Factory Reset and then setup the phone after. See if it works
02-14-2023 05:23 PM
@jd444 wrote:I purchased it through bell
Your Bell Samsung 21+ from Bell should work with PM.
Is it a new phone or a refurbished phone which was used on Bell network before?
If it is a refurbished phone, it is still configured for the Bell network.
BTW, did you restart your Bell phone after inserting your new PM SIM card?
If not, restart your phone now before creating a support ticket. It is as simple as that you need to restart your phone to give your phone to configure it for PM service.
Good luck.
02-14-2023 05:19 PM
Put your pm Sim card in your S21. Skip the set up and go straight to using the phone. You should see public mobile pop up on the top of the home page.
02-14-2023 05:10 PM
@jd444 If you purchased from bell I think it’s safe to say it’s compatible
02-14-2023 05:09 PM
02-14-2023 05:09 PM
02-14-2023 05:08 PM
@jd444 S21+ should work without problem
did you get the phone from trusted source? Check if the phone is blacklisted here:
https://www.devicecheck.ca/check-status-device-canada/
