04-30-2022
03:03 PM
04-30-2022
05:12 PM
computergeek541
I have a Samsung A52 that I got from Pakistan will it be compatible with the network?
05-04-2022 08:55 AM
Yes, that's the exact model!
04-30-2022 08:14 PM
@jdoe Can you confirm if your A52 model is SM-A525FZKHMEB ?
if that is true, this is your phone available bands and BOLD are the one compatible with PM
3G : B1(2100), B2(1900), B4(AWS), B5(850), B8(900)
4G: B1 , B2 , B3 , B4 , B5, B7, B8, B12, B17, B20, B26, B28, B32, B38, B40, B41, B66
Looking at this, I think it will work nicely
04-30-2022 07:12 PM
I haven't looked any further but I think I noticed this before in phoneland but forgot about....you're it can you tag me elsewhere? French side notwithstanding.....
To pre-verify your account include in your private messaging only your full name, address, email, phone # and 4 digit acct pin #.
04-30-2022 03:59 PM
It should but not as well/seamlessly as the Canadian model.
04-30-2022 03:40 PM
Hi @jdoe your Pakistan variant might have less frequencies, should be just these
3G Band HSDPA 850 / 900 / 1700(AWS) / 1900 / 2100
4G Band: 1(2100), 3 (1800), 5(850),
7(2600), 8(900), 20 (800),
38(2600), 40(2300), 41(2500)
04-30-2022 03:22 PM
Phone will work on Public mobile.
Here are the specs of the phone:
https://www.gsmarena.com/samsung_galaxy_a52-10641.php
| 3G bands | HSDPA 850 / 900 / 1700(AWS) / 1900 / 2100 |
| 4G bands | 1, 2, 3, 4, 5, 7, 8, 12, 17, 20, 26, 28, 32, 38, 40, 41, 66 |
Public Mobile uses the following frequency bands:
04-30-2022 03:20 PM
One reference seems to say all models should be fine. Can you give us the detailed model #. SM-A52......
04-30-2022 03:14 PM
https://www.publicmobile.ca/en/on/get-help/articles/check-your-phones-compatibility
Most reliable test would be if you find somebody with PM service and test his SIM in your phone. Canadian version of this phone is preferable but it is no secret that international phones work too.
04-30-2022 03:10 PM
