06-21-2022 12:47 AM - last edited on 06-21-2022 12:54 AM by computergeek541
At: https://www.publicmobile.ca/en/ab/sim-card
the drop-down arrow for checking phone compatibility does not work.I tried two different browsers with the same result.
06-21-2022 02:18 AM
@musicollector wrote:Thanks for the quick response. It is a OnePlus 5.
This phone will work fine.
06-21-2022 02:14 AM
06-21-2022 01:29 AM
The compatible PM site has been down since the beginning of January.
What is the make and model of your phone so we can double check the frequency of your phone to see if it matches PM's 3G and 4G/LTE frequencies?
06-21-2022 12:53 AM
@musicollector wrote:At: https://www.publicmobile.ca/en/ab/sim-card
That compatibility checking website hasn't been working for a while. Please note that no such list will ever be 100% complete and they're only meant as a reference point. Which phone model are you wondering about? It's important to make sure that your phone supports both UMTS band 2 and UMTS band 5 or else phone calls won't work at Public Mobile.
