Phone calls
bettylai
Can’t make an out going phone call after the activation of number transferred.
7 REPLIES 7
bettylai
it worked! so annoyed, seems like a dumb reason for things not working
bettylai
do you see this often? that leaving the prev carrier's SIM in the phone can cause problems?
it was mostly that the phone case was hard to remove, that's why i left it
will try this and report back
hi @bettylai it is time to remove the old carrier sim card.  After doing so, reboot the phone the phone should be fully functional
bettylai
Hi,
Can receive calls and text. Cannot text out and call out. Data appears to be working.
Restarted phone, reset iPhone network settings. Using eSIM, so no SIM card to take out and re-insert.
Left old SIM card in phone the whole time, so did not interrupt porting process. Replied to porting texts within timeframe.
@bettylai
send  a  private message   To CS_Agent
Hi @bettylai
you have neither outbound nor inbound calls? or just not outbound? and data works?
if nothing work (no inbound/outbound and data), it is a sim card setup problem on the system.  you need support to look into it
 you can submit  ticket by direct message:
  But if you have inbound and just not outbound, then it is a porting problem.  You need to contact porting support team in that case
TheSterlinger
@bettylai
Can you receive inbound calls or text?
