07-17-2019 10:33 AM - edited 01-05-2022 08:20 AM
Yesterday I received an email indicating that I had less than $10.00 left on my plan. I have hardly used the phone since the last payment. Today, I can't receive or send calls. Very distressing. Last time I received this message I was told not to worry about it. I would like my service restored. I just checked my account and there should be ample time available.
Why is this happening?
07-17-2019 11:16 AM
@dschmidt20 wrote:Yesterday I received an email indicating that I had less than $10.00 left on my plan. I have hardly used the phone since the last payment. Today, I can't receive or send calls. Very distressing. Last time I received this message I was told not to worry about it. I would like my service restored. I just checked my account and there should be ample time available.
Public Mobile will not send an email saying anything about an amount of money left in your account.
They'll *text* you to remind you that your term is about to expire. They'll text you to say that you have 10 minutes left of your limited prepaid minutes. They'll text you to say that you have 10 texts left of your limited prepaid texts.
In the self-serve under My Data & Add-ons you will see what currently active valid counted features you have available. If you don't see expected features there it means you've used up that counted feature.
07-17-2019 11:05 AM
Log in My Account and note if your plan is Active or is it Expired ? When is your plan renewal date ? Plans run for 30 days or 90 days. If you haven't put your credit card on file, the plan will expire at renewal, if there isn't enough $$ to cover the cost of your plan renewal. You can call 611 for info as well. If you do have a cc on file and still a problem, then you can add sufficient funds to your account by calling 611.
If all else fails, follow others advise and send a message to moderators. Please be patient as it could be 48 hours before you get a response...usually much less.
Good luck.
07-17-2019 10:39 AM - edited 07-17-2019 10:39 AM
@dschmidt20 Are you on the limited $10 calling plan? If yes, login into your selfserve account and check the status of your account is it active? Also check the minutes counter on your account if it's not listed it means that you used up your minutes.
If you still believe the is a problem with your account then you need to notify PM directly via a message. To contact Public Mobile click here. The link sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
Moderators are available: M-F from 8 AM to midnight Eastern time and S-S from 8 AM to 10 PM Eastern time.
Note: Moderator Hours are subject to change, but you can always find the current times here
07-17-2019 10:37 AM
When you log into your self serve account - what is the status ?
Try the lost phone trick. To report your phone stolen. Login to your account. Choose Plans and Add-ons tab. Then choose Lost/Stolen Phone tab. The choose Suspend Service tab. Logout. Wait few minutes. Login in and report your phone found Another thing to also try, would be adding a $1 payment to reactive your account. If you still have problems tthen contact a moderator by messaging them. Moderator can be reached at https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
07-17-2019 10:37 AM
I would recommend messaging the kind folks at the Moderator_Team via this link to investigate your account and to provide some additional insight into your issue.
It helps to provide a detailed description of your problem and what your resolution goals are so they can best assist. If you are having troubles contacting the Moderator_Team, refer to the following knowledge base link. Expect a response within 1 hour or up to 48 hours depending on volumes...
Best of luck!
