Phone Plan
06-06-2023
08:41 PM
06-07-2023
01:21 AM
computergeek541
Hi
I am not able to make any outgoing phone calls. It says “can’t be completed as you have used all available minutes” and instructions to purchase more minutes. Problem being I have an unlimited provincial calling monthly plan. Please help as this is my only method of communication and if an emergency happens I cannot call anyone.
Thank you
Service
06-06-2023 09:49 PM
I will look but I don’t make any calls out of province anyway just the lower Ontario area to family and friends. Anything out of country is only through messenger on the internet.
06-06-2023 09:32 PM
Yes, already tried a hard reset and toggling the air plane mode switch among other things. All numbers already have the 1 in front. I will message the above for further help. Thank you for posting it.
06-06-2023 08:49 PM
To be certain, @Jaimewillis , you are on the Provincial calling plan, and NOT the Canada-wide plan?
You should be able to move over to the Canada-wide for the same (and possible less) money.
Have a look at the available suite of plan offerings - PM Plans
Download the PM app and you'll see additional 3G plans at $25 and $15.
06-06-2023 08:43 PM
@Jaimewillis this is a common glitch 😞
Usually a device reboot should resolve the issue
also, make sure you put a 1 in front of the 10 digits number when you dial
if nothing works, then you will need support to clear up the issue for you. Please message them here:
